How Do You Block An Incoming Call On Android Phone?
Asked By 5 points N/A Posted on -
Hello everyone! I guess each one of you have must receive a wrong call on your mobile once in your life, and same is me! But, unlike you I am not so good with gadgets and don’t know how to stop all this. If you can tell me how do you block an incoming call, it would be much helpful? Thanks!
Answered By 0 points N/A #298314
Here are some of the naïve ways of blocking the unwanted calls on your mobile:
  1. From the call log
Select the number you want to block. Next, tap the 3-dot menu button, and choose Add to Reject list. It will disable the wrong numbers from reaching you.
  1. From the Contacts list
If you want to block the number of a particular being, pull up your contacts, choose the person, and hit the pencil icon. Now, in the upper corner, go to menu, and then check the All Calls to Voicemail checkbox. This will transfer that call to your carrier’s voice inbox.
  1. From the Settings menu
Go to Settings, then Call, and then Call Rejection > Auto reject List > Create. Now, a search box will appear, enter the name or number that you want to block, and it will get add to the Auto Reject List.
