Hello experts,
How do you bookmark your manga? I am using Mozilla firefox browser in my computer with an operating system of windows 7 64 bit. I can’t seem to find the right button or setup to set this manga page as a bookmark, tell me more about the settings of Mozilla firefox . Thank you.
You need to select the customize toolbar and then you can place a bookmark icon for your desired image. You can also choose the dropdown to select the bookmark. I think you will be able to add bookmark by simply looking at this image:
Hello Lindsay Wendy,
Just click the star icon on the upper part of your browser.
Beside the URL and the Refresh or Cancel Button.
Then Click DONE.
Hope this helped you!
Bookmarking in Mozilla Firefox is pretty easy. You can do it in two simple methods. You can do it either through a simple hot key, or a simple right click. Here are the two methods:
Method 1:
Just press CTRL + D on your keyboard and it will automatically bookmark the page. Once you press CTRL + D, a confirmation box will appear. Once it appears, just click done to confirm it.
Method 2:
Right Click the mouse to open up a pop-up menu. Once the pop-up menu appears, choose "Bookmark this Page". Again, a confirmation message appears. Just click "Done".
Once you have bookmarked the page, you can navigate your bookmarks through the "Bookmark" menu found below the "minimize, restore, and close button". Just click the "Bookmark menu" so it will open up a menu where you can see your bookmarked pages. Enjoy!
