How do you convert a DirectX file format?
I need to convert DirectX file format so I can open and save .3Ds and .X files. I have tried some applications such as Milkshape and TrueSpace3D but it cannot import .X files no matter what I do.
Looking forward to hearing back from you.
Thanks a lot,
Down Snieves
Answered By 5 points N/A #167802
Hi Down, thank you for sending this in.
I found a very handy software after a bit of scouring the web. This is the link:
https://www.okino.com/conv/imp_xof.htm
Every bit of information as to how that program works in that website. You may also contact them for support. I'm sure you know your way around such programs since you tried using sort of similar programs to try and convert a DirectX file. Hope this helps. If you have anything else to ask, please do not hesitate.
