How do you create ISO file Mac OS X?
I need steps are a video link to show me how to burn ISO file Mac OS X. In order to burn image files , when burning dvds on my mac, this information is needed. Really confusing. I need a easy way.
Hi Karamhobbs,
I have read the issue about your problem. There are several step to burn ISO on MAC
1. Insert blank CD/DVD to your ROM
2. Wait a minute, then the box like below appear, choose open disk utility
If the there’s no box show, you must execute application manual, /Applications/Utilities
3. In disk utility window, click burn icon.
4. Choose the ISO file
5. Burn
That’s the step. You can watch the video tutorial
Hope this post help you.
Cheers!
ISO is one kind of disk image file. There are many image CD/DVD burning software on the internet for Mac. You can just download and install them and enjoy.
1. UltraISO
2. AnyToISO
You also can simply:
* Insert a blank disk and format it.
* Install any compressor software and extract the image copy into the cd.
You can also use Disk Utility to perform this task.
