Pam Gouin
10 points
Posted on - 04/03/2013
Hallo! I want to make a label in visual basic to be able to clear the contents with a button once it has been filled in. One should be able to select a button to be directed to the label before filling it in. Further I would like someone to define label in visual basic as defined by Microsoft.
How do you define a label in visual basic?
Hello there Pam,
Label is one of the controls in the visual basic that are very usable. They are use to define a name, an information and etc. Labels are also used as an indicators before text boxes. It is also used as a piece of text that gives a user a note or directions and instructions on what to do.
Hope this helps you.
Regards, Roland.
