How do you get new search rules from a pst
How are you all? Currently I am facing a serious problem in new Microsoft PST capture tool. Can anyone tell me about the detail of search rules from a PST?
Thanks
Cromwell ron
Thanks
Cromwell ron
There are some limitation with Microsoft's PST tool. However since you did not mention the cause, So it's hard to understand the issue. Never the less. I' am going to write few steps form where you can change the settings or properly configured it.
Simply Open the Microsoft's PST console Click on tools—-Setting—- change the way you want it to behave. Make sure that it's on sync it to exchange, So its becomes up to date. Another thing that you can do is reinstall the software. If your issue remains the same. Then come -up with exact error message.
Thanks
