How do we get to listen to WhatsApp voice notes without using low volume or headphones on or devices? It seems really embarrassing when one listens to voice notes on speaker phone regardless of the information it carries.
How Do You Get To Listen To WhatsApp Voice Notes
Nowadays our smartphones are equipped with a special sensor known as the proximity sensor. Its range varies from device to device and can be used for detecting the degree of closeness. However, talking in terms of WhatsApp voice note, have you ever notice whenever you place your finger near the front cam, the voice note stops all of a sudden. This feature enables you to use the speaker at the top of your screen in order to hear WhatsApp voice notes.
