How do you install a motherboard
I know this is a bit technical. I would like to upgrade my computer's motherboard. How would I go about removing and installing a new one.
Hello Danny I Sanders,
To uninstall your old motherboard and replace it with a new one, follow the steps below:
1. Take out the entire cables attach to the CPU case.
2. Take out the screw that holds the external shell of your computer and then simply slide the case to open it.
3. Turn the computer down on the right side so the left side will face in front of you.
4. Take a picture of the current motherboard or draw out a diagram so you know the settings of your old motherboard while it is attached to the drives, cables and everything.
5. After taking pictures, gently take out the entire cables attach from your motherboard.
6. Take out all the screw that holds the expansion cards to the CPU case.Â
7. Take out the entire cards from your motherboard and then remove the old motherboard to the case.
8. Ensure that you already take out the back panel of the motherboard from its case.
9. If you find that the case has some dirts, remove it with a dry cloth and then install the new back panel from the motherboard.
10. Repeat the same steps above and install your new motherboard. Plug all the cables accordingly and be very careful when you plug the power supply unit.
Hope you will fix a new motherboard by these steps.
Good Luck.
Hello Danny,
The following steps should help you install a new motherboard successfully:
Carl
