Hey everyone,
I am looking for some type of software that can record Skype calls on a local network. Skype has no built in feature to record calls and I would like the option of saving my audio and video conversations with simple software.
I would like to be able to record between video and audio and audio only, and also be able to record Skype conversations between multiple people at one time. Something preferably with an easy to use interface also.
Thank you very much for the help.
How do you record skype calls on a local network?
Hi Gary
There are many programs that can record audio and video calls from Skype. I will give you the better ones. For Mac there is a Skype add-on that may be good for you and it is called Call Recorder. If you are a Windows user use Pamela, Evaer or Supertintin. If you are looking for a free alternative use Skype Call Recorder.
Hi Jonathon,
There is some software that you can use to record any conversation you want to on Skype. Here are the lists of software you can use and the good thing with this software is this is supported by Skype:
1. Pamela. This is compatible with Windows Operating System and you can download this for free. Â
These are the features of this software:
  You can record video on Skype
  You can record chat on Skype
  There is a Conference Call manager for Skype
  You can record calls on Skype
  There is a Call Scheduler for Skype
  There is a Call Transfer for Skype
  You can set to record a call automatically
  There is a Mono/Stereo recording option
  It also has an Answering Machine
  You can make cute mood messages
  There are Podcasting and Blogging
  You can play music even during your calls
2. Wiretap Studio. This is compatible with Mac Operating System. This software allows you to record and even edit your audio or video from iTunes and Skype. But unlike Pamela, WireTap Studio is not free you can buy this for $65.
3. MP3 Skype Recorder. This is compatible with Windows Operating System and you can download this for free.
  You can set you recording in manual or automatic.
  You can record calls from Skype, P2P, and other calls you made through Online.
  You can also record Conference Calls made from Skype.
  You can split yourself and the person called to different tracks and can even save it separately.
  This a user friendly so you can learn to use this easily.
4. IMcapture. This is compatible with both MAC and Windows Operating System. All recordings will be saved as MP4-AAC format.
  You can record audio on Skype
  You can share your all recorded calls  * New Skype 5.0 support
  You can record Audio or Video from other online applications
  You can start and stop the recording any time you want
