Hey guys,
I need to repair edb file linux. I need to repair the exchange database and also convert it to PST if that is at all possible. I need software or a method to perform one but hopefully both of these activities. Any help would be great, thanks in advance.
How do you repair edb file linux?
Hello Susan
EDB is the short form for Exchange Database.
It is possible to repair the EDB file, by executing eseutil /p, this command will repair the EDB file and try to restore it to normal stage.
As soon as the repair is complete, you can convert the EDB to PST, by any of the tools mentioned below –
EDB Converter Software – Provides great conversion features with many options enough to carry out most complex conversion processes.
EDB File to PST Utility – An interactive GUI helps powered by easy to use instructions does a great job of doing the necessary conversion. The software is not free, but a no obligation trial is available which will help to make a final decision.
Hope these steps help you in the conversion.
Mclean Buono
