How do you save a MS word document?
Hello Abayasingha41,
It's my pleasure to help you.
As you asked it is not difficult to do. Just press Ctrl + S on your Keyboard or manually you can click the 'Save' button on the Quick Access Toolbar, then a dialog box will appear.
Just give a path for the file to save and click save.
Do it and experience it.
Thank You,
Greetings,
In saving word document, you can press ctrl+s for saving, It will prompt that you need to enter the file name. Or you can go to the File (upper left) and choose save. You can also choose save as so that you can choose what type of file you want to save the document.
I hope it will help.
As I am using MS Office 2010 Professional, which create .docx file, as Office 2010 is backward compatible but older version like MS Office 97-2003 doesn’t support this file extension.
So that first is checking the purpose or the destination of the file for it is going to be created. If the user is able to use as it is created then fine just go to Office button, choose save, select the desired folder name the file and save it.
Else choose the file type for backward compatibility and do the above mentioned process.
Dear,
In order to save a document in MS word you can use two process. For keyboard use just press Ctrl+S, a popup box will show. There you put the file name and then save.
For mouse use click on Office Button (office 2007 and higher version), click on File button for (office 2003, XP and lower), then click 'save'. A popup box will show put the file name and then save.
Hope this will help you.
Thank You.
This is very easy work but you need some basic about ms word, just follow the step given below,
Click the file menu from the menu bar and click save button to save, put a name of the file and click save again.
Or you can use the keyboard shortcut menu, Just press Ctrl+S button, give a name of the file and click save.
Hi, Abayasingha41
This is a basic knowledge for Ms Word Application.
You can simply click the button on the upper tool bar and click the small blue disk icon and something will pop out on where you will go to save your document. I think you need to look for tutorials.
I can suggest you some links that would help you with your problem,
Hope that helps you a lot.
For saving the document to a folder or in another place like HD, portable drive etc, just click saves the button image. A new dialog box will open where you will put the location and your chosen file name to save the file with your given specific name.
There are other methods too to save a document. You can also save a copy of the file by clicking the option on Save As in the file menu and repeat the same process of giving the file name and location to save.
Press enter to finish shaving. If you want to save automatically the documents you are working while you work to recover them if problem of power failure of some other failure occurs, choose the menu of Options in the Tools menu and then click over the Save tab option.
Select the auto recovers option (Select time) in the check box and press enter. This will save the document as per given time. Remember this is not an alternative to regular save option. If you do not properly save the file after auto recovery all data will be lost.
Saving a MS Word 2007 is a very easy process. First click on Office Button that is top left of the screen, then click Save As. A new window will show name Save As and write your file name then click OK. If you wish, you can select your folder where you want to save it.
Hello Abayasingha,
Use the Hot Key to save your MS Word documents that are Ctrl+S. Press it once your document will get saved. It's a good practice to save your document after a minute or two to avoid the data loss due to power failure or any other reason.
Hi Michele,
Try to check if your speakers are connected and turned on.
You can also check on the menu bar, click Tools > Options > Audio Settings.
Press ►. If you can hear a sound, it means your speaker is working correctly.
Check you're not on mute, and turn up any volume control knobs on your speakers.
Make sure that your call settings are correctly set up.
Check your call quality settings and ensure that no issues are identified in the Computer and Connection tabs.
I hope this can help you.
nairb_opawg
When you finish your MS document and save it, first you will see that if there are any mistakes, you can correct them and go to the top, there will be an option to “open”, select that and there will be option to Save, select that and save that.
The second step is after completing your document, close MS office. You will get an option of saving automatically, just click on YES and your document will be saved.
If you want to alter your document, just open your document and alters it, and after that open menu and click on save as. Your document will get saved.
You have two easy ways to do it, no matter what version of MS Word you use.
By pressing Alt+F+A in that order, you can save a file that has been just created (I mean there is no previous file with that name in the directory). You will be invited to choose a path and a file name.
The second way, which is also working for new created files, is to simply press Ctrl+S and you will also be asked to enter the path and file name. This maneuverer is also including the previous procedure, therefore this is a more common way to save a file.
Saving an already created file (previously saved at least once), Ctrl+S is enough and you will not be prompted to enter any other data.
I presume you are not quite new in computers and know how to choose a path and file name in the dialog box that Windows displays in such cases. If not, please let me know and I will guide you further.
Press Ctrl+S to save a MS word, excel document.
However, then they ask you that where you want to save the document?
Then you select desktop. And click the OK button.
Then it will be done.
