How do you send large file through email?
Is it possible to send large files via email? The size of the file that I am going to send is 700mb.
How can I send large file through email?
Hello Michael.
Sending e-mail attachments of that size is a very bad idea. Most e-mail servers set a limit to how large any user's Inbox is as well as how large an attachment it will send or receive. Even Gmail has a 25 megabyte limit to its attachments. If you insist on sending it via E-mail then you should split it into several chunks.  Most file archiving programs such as WinZip, WinRAR or 7-zip has options to split it into volumes. Make sure to send it in batches to give time for the recipient to download each e-mail first before uploading another batch. Doing so will avoid clogging up the mail server.
One option that you can do is to upload the file to a file server. One example is Dropbox (https://www.dropbox.com/). You can sign up for free and get 2GB free space. Just share the link to your intended recipient and let them download it through dropbox.
Hope this helps!
Thank you for giving me such an excellent idea on how to send large files via email. I had them chopped in a different file using the website that you gave.
