I would like to stream live images to my webpage but I do not have any clue how to go about doing this. Could someone assist me with critical assistance in getting this job done? I need to know which software to use and how to integrate this into the webpage source code. Please give a brief overview of the steps that I would need to take to achieve this.
How do you stream live videos on your webpage?
Hi Esteban K Benton,
I understand the challenge you are facing. I will outline two methods that you could use in order to stream live videos on your web page.
Method 1
You can use a service called DaCast. Its website is:Â https://www.dacast.com/stream-live-video-on-your-website/
Once on the website, you can sign up for the service for FREE (No Credit Card Required).
All the simple steps needed are shown on the website.
Method 2
An alternative method to the one mentioned above is the use of NCH software.
This software can be downloaded from: https://www.nchsoftware.com/broadcam/
There are two versions of this software: the Free version which has limited functions and the Premium (Paid) version that has more advanced options.
Once you have downloaded and installed the software, the setup process will be quite simple.
Once you select the method that suits you best and implement it, you will have live streams on your webpage immediately.
Thank you
