How do you update a Blackberry?
Hi, I have a Blackberry Torch 9680. I have BlackBerry Desktop Manager installed on my MAC. While running the software update through it, I get an error message that says "cannot detect the software update".
Please suggest me the right steps to update my Blackberry OS.
Best Answer by RobertDuncan
Answered By 0 points N/A #161560
To upgrade the Desktop Software:
1. Close the BlackBerry Desktop Manager if it is running actively.
2. Download the correct program to upgrade the desktop software.
3. Run the file that you just downloaded by double-clicking on the exe file.
4. The Choose Setup Language dialog box will appear, choose your language and then hit the OK button. This will launch the Welcome window.
5. Click the Next button. The Country and Region option window will appear on your screen.
6. Choose your preferred country and then click the Next button. You will see the License Agreement window. Read the agreement and accept the terms and conditions by clicking on Yes. This will launch the Customer Information window.
7. Just simply follow the on-screen instructions.
To confirm if the desktop to handheld connection is already active:
1. On the Desktop Manager software, select Options and then click on the Connection Setting. This will open the Connection Setting dialog box.
2. Hit the Detect button. You will see a warning dialog box, asking you to confirm if your handheld is already connected.
3. Click the OK button. You will be notified when your BlackBerry handheld is already connected.
Answered By 0 points N/A #161561
Hello Orchid Flower,
I have read your question about the error that  pops up when running the black berry desktop manager, this is mainly caused by a number of reasons including;
At times the drivers of black berry are corrupt and end up not working, so download and reinstall black berry to your PC, after you restart your computer and connect the desktop software again.
Most PC’S have many different ports some from the front others at the back, try to connect from the back since the back ones are near to the motherboard, so they will be more detected than the front ones.
Sometimes the User Control Accounts block the black berry software so they need to be turned off to get detected, this happens mainly when you are using Vista or Win 7
Here are the steps when Using Vista
1. Click on the “Start” menu and then click on “Control Panel”
2. Click the “User Accounts” icon and then when in the User Accounts Screen click again on “User Accounts”
3. Click on Turn User Account Controls on or off, this will bring up a prompt which you will hit “Continue” on.
4. Clear the “Use User Account Control to help protect your computer” checkbox. and then click “OK”
5. You will be prompted to restart your computer, click “OK” or “Yes”. If you are not prompted then manually restart your computer for these changes to take effect.
And when using Win 7
Click on the “Start” menu and then click on “Control Panel”.
2. Click on User Accounts and Family Safety
3. Click on User Accounts.
4. Click on “Change User Account Control Settings”
5. Move the slider to the bottom and then click “OK”
6. Restart the Computer.
Restart your computer  and check whether it has been resolved.
Answered By 590495 points N/A #320079
Updating your BlackBerry phone can be done easily with a PC suite. But first, you need to check your phone for the version of the BlackBerry OS running on the device. If your phone is running on BlackBerry OS 7.1 or earlier, download and install one of the following:
If your phone is running on BlackBerry 10 OS, download one of the following:
  • BlackBerry Link for Windows – it supports Windows XP Service Pack 3, Windows Vista, Windows 7, and Windows 8.x and requires Microsoft .NET Framework 3.5 Service Pack 1.
  • BlackBerry Link for Mac – it supports OS X 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, and 10.11 El Capitan.
If your phone is running on BlackBerry OS 10.3 or higher, you can use one of the following:
  • BlackBerry Blend for Windows – it supports Windows 7, Windows 8.x, and Windows 10.
  • BlackBerry Blend for Mac – it supports OS X 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, 10.11 El Capitan, 10.12 Sierra, 10.13 High Sierra, and 10.14 Mojave.
You can also update your phone via the web browser. Go to BlackBerry Software Updates. For this to work, you need to use Mozilla Firefox or Microsoft Internet Explorer 5.5 or higher. When the browser prompts you to install an add-on, install the add-on. Once the add-on is installed, you should see a “Check for Updates” button.
Connect your phone to your computer using the USB cable then click that button on the browser.
