How do you use a backup to restore unknown data?
How can I restore unknown data with a backup system using a reliable software which runs scripts that install data recovery?
Hi Alicia,
You are looking for a data recovery software and I have the perfect one for you. I am suggesting you Power Data Recovery. I have used it myself and it yields perfect results. The software is very small in size but powerful. It recovers data of a drive if the drive is corrupted and there are bad sectors in it. It is a good software because it is able to recover data of a drive even after the drive is formatted. Download the Powerful data recovery software. Then unzip and install it.
Double click the application.
Select a drive which you need to recover.
Click recover and see as the software recovers data for you
Thank you.
Hi Alicia,
The best according to me is Total Recovery Professional Nine. Your data is safe and can be recovered or recalled according to your needs. It saves the backup of photos, videos, emails, files, folders, favorites, applications; Windows and Winchester drive partition's data. A tryout edition is available for 30 days. Get it from the following link:
http://www.farstone.com/software/totalrecovery-pro.php
JK
Notifications
