With the current hype about 3D printers, I feel like I am the only one who does not know about 3D printing. First, what is 3D printing? Particularly, what is the UP 3D printer? If I buy one, will it be difficult to set up? What do I need to begin using it?
How does the 3D printing technology work?
3D printing is also called additive manufacturing. This process helps to create 3D objects from digital image or file. This process of creating 3D objects is called additive manufacturing process. To obtain the 3D effect the process creates layers after layers till the entire effect comes.
An UP 3D Printer converts the ideas from fantasy to real world objects within a time slice. An UP 3D Printer comes with 2 models. One is UP Mini Desktop 3D Printer which is smoothly designed and has an inbuild chamber and the another model is UP Plus 2 3D Printer which is designed for higher clarity resolution of 150 micron and larger creating quantity. The UP 3D printers are engineered to give life to the creations.
The assembling of UP 3D Printer is not a difficult task. It is pre assembled before out of box and are just need to be plugged in to desktop. It will creates 3D print in just 15 minutes.
Nearly all types of computer that are able to run the visual printer driver can carry on the 3D printing process. The printer driver supports almost all operating systems including WindowsXP, Windows7, WindowsVista, Windows8 with all 32bit and 64bit.Â
