How does anybody export a Microsoft word file to Microsoft excel?
Anybody need to import a file from Microsoft word to Microsoft excel to count, how can anybody export a Microsoft word file into Microsoft excel?
Hello there,
This is actually a quite easier than you think. I know what you are thinking, why is this guy so cocky, who is he to tell me what to do.
Well I’m not that guy; I’m just trying to help you.
The best way to import data to Excel is next: When you open Excel 2007, you will have a ribbon called Data. Click on it.
There you’ll have something called Get external data – From text. Click on it, find your word document, click on it, choose import, next and finish, and that’s it!
Now you have your Word in Excel file!
Open a new excel sheet and follow the steps:
Dear Lyndon Miller,
How are you? Hopefully, you are good. I found a nice software which can convert Microsoft Word to Microsoft Excel. It’s very easy to use. So I think you will be able to download and then install it. And then you use this nice software and it will be very helpful for you. Download this software from this link.
http://download.cnet.com/MS-Word-To-Excel-Converter-Software/3000-18483_4-75728329.html
Best wishes for you. Thanks.
