I want to put a number of songs in my Galaxy s2 android Ice Cream Sandwich. I just created a library in my phone and I want to put the songs from my pc to the phone. How does Galaxy s2 add mp3s to music library?
Hello John Anderton,
It can be very easy to do. Samsung S2 is an in build SD Card. This is built in Storage. On that you can create a Folder for Movie and Music and you can upload easily. After that you should safely remove your device. Then your device will detect your Media folder.
Otherwise, you can download KIES Application from Samsung site. And Install that. It will help you to upload your Media Library.
Thanks
Simon
If you have a Samsung Galaxy S2 Smartphone and you want to transfer music files or songs from your computer to your phone, the best way to do the transfer is with Samsung Kies. Go to Samsung Kies download page and download the version designed for your phone.
If your phone is running on Android 4.3 Jelly Bean or higher, download Samsung Smart Switch otherwise just download the native Samsung Kies. Samsung Kies supports Windows XP, Windows Vista, Windows 7, and Windows 8.x. It requires 2 GHz Intel Core 2 Duo or faster processor, 1 GB RAM, 500 MB free space, 1024 x 768 minimum screen resolution, and Microsoft .NET Framework 3.5 Service Pack 1.
For media playback, it requires Windows Media Player 10 or higher and Microsoft DirectX 9.0c. For Samsung Smart Switch, it supports Windows XP Service Pack 3, Windows Vista, Windows 7, and Windows 8.x. It requires 3 GHz Intel Core i5 or faster processor, 512 MB RAM, 200 MB free space, and 1024 x 768 minimum screen resolution.
For Windows XP, Windows Media Player 11 or higher is required for media playback. For OS X, it supports OS X 10.5 Leopard, 10.6 Snow Leopard, 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, 10.11 El Capitan, 10.12 Sierra, 10.13 High Sierra, and 10.14 Mojave. It requires 1.8 GHz Intel or faster processor, 512 MB RAM, and 100 MB free space.
