How does Intel’s Dual Core differ from Core 2 Duo?
The core 2 duo CPU has superior performance
Intel Company is pioneer to introduce Intel dual core CPU. On a single die Dual core utilize dual cores. For instance, in a single package it has two chips. It resolves the issue of overheating of the Pentium D with no compromising on the quality performance.
The next generation processors from Intel are Intel Core 2 Duo processors. Intel core2 is a super over clocker. Core is a new structural design used in these processes. These processors run fresh due to its new structural design.
I expect now it will be simple for you to select a superior processor for your laptop after clearing this difference between these two processors. I can search further detail about these if you really want.
The Core 2 Duo and Dual Core processors are CPUs that have two cores on a single die in other words; it has to chips in one physical package. Both have the ability to bring up the CPUs processing speed 3 times faster than a single core CPUs and it’s comprised with the 64-bit technology.
The difference between these two processors is just in the semantics; Core 2 Dou is purely a name particular to an additional current version of a Dual Core processor. Therefore, a Core 2 Duo processor is only a subset of all the Dual Core processors that are carried out of the market.
The two processors are often confused with one another. Core 2 Duo processors all have dual processing chips, but not all Dual Core processors are labeled with Core 2 Duo.Â
