How does operating system language plus hardware help in supporting computer graphics?
Hello there,
How does an operating system language plus hardware help in supporting computer graphics?
How can I illustrate with example?
Hello there,
Hello Grace,
An Operation system language does not corelate to support computer graphics. as they are independent of operating system. The OS must support the system software which is used to enable the Graphics.
While Computer Hardware is most important for Computer Graphics, as any Graphic program require memory to load himself, So more of Ram in your Computer Better the Graphics. Even in improved Graphics System a Special memory is reserved as Video Ram to improve graphic performance.
Shwanj Whudson
