smadisonny
10 points
Posted on - 06/08/2012
It really is possible to have 2 OS run in one MAC and Parallels Desktop 7 is making this technology possible.
What are the steps that we need to do to be able to do this? Were there any drawbacks reported or effect on the system's performance?
How does Parallels Desktop 7 for MAC work?
Parallel Desktop for Mac is a solution for running your windows applications in Mac OS. By having this parallel desktop in your OS you can at a time run both windows based applications and mac based applications without any problem.
How to setup this is just bring all your mac based applications and install those and run as you do it on your Mac OS.
When it comes to performance you can customazie the level integration of both the OS like Mac and windows without compramising the existing performance.
You can run this on an iMac, MacBook Pro and even on the latest MacBook Air. Just download and install the tool.
