Hey Techyv,
My computer has been crashing and some of my programs have been freezing regularly. I was recommended registry first aid platinum but I had a few questions about the program. Can it in any way damage the registry and remove something it shouldn't of? Can it also fix the registry where I have moved a program from one drive to another?
How does registry first aid platinum function exactly?
Hello Katherine,
The symptoms mentioned by you indicate there could be issues with the registry.
You should definitely try using registry first aid platinum, it is an award winning tool and has received positive reviews from the users who have tried it. It uses advance algorithms during scanning the registry.
I have personally been using it for a while, I generally go through the scan results to first understand the deletions or fixes that are going to happen. I am yet to see a false alarm or incorrect problem being reported. Which is why I don't think it does any damage to the registry or removes anything it shouldn't.
But for precautionary measures you should always take a backup of the registry before making any changes and the software provides an option of taking a backup too.
Hope this information helps.
Mclean Buono
