How to Downgrade a PSP
Now that you have all the files and instructions necessary to downgrade your PSP, here are the instructions on how to proceed:
If you see a 1.50 firmware logo after your PSP reboots, then you have successfully downgraded your PSP, and access its amazing features.
In case you still experience problems downgrading your PSP or you tried downgrading your PSP and it is "broken" now, I highly recommend the PSP Downgrading Guide below. It comes with easy to follow instructions + audio / videos. With this guide you will be able to downgrade, upgrade, downgrade, upgrade, downgrade… do as you wish and need!
The usual reason why we need to downgrade our PSP firmware is for us to play copied and downloaded games that we can get from the internet. For this, we can get rid of purchasing UMDs and will save us a lot of money. And will even have a chance to copy your friend’s games. After downgrading the PSP firmware, you can be able to play homebrew and then copy games; there are also lots of applications that you can get for free and can even copy DVD movies to your PSP without region limitations.
Downgrading your PSP firmware only takes a few minutes to do this. You can downgrade PSP with firmware 5.50 and lower. PSP3000 is not included. Downgrading other versions may be too tricky especially if its a newer version. And there are risks on performing it. And it can also void the warranty.
To downgrade your PSP firmware, you need to purchase Pandora Battery and a memory stick. For these, you can go to the the link below:
