I am running the Window 7 currently. But it have lots of function that i do not like. Acutely i have to do only the basic Microsoft office work on it. So i did not like the version now i want to do back to the Window XP is there any way so i can do that.
Can anyone help with sole this issue I am waiting friends give answers fast.
How to downgrade windows 7 to xp
Open your Windows 7 drive (usually C drive) and make sure that you haven’t deleted the Windows. Old folder, which was created by Windows while installing Windows 7 on XP drive. Note that without the help of Windows. Old folder you won’t be able to downgrade from Windows 7.
Now check the amount of Windows. Old folder by right-clicking and then selecting properties. Make sure that Windows. Old folder size is less than two period the amount of free breathing space available on Windows 7 drives (C drive)… If the Windows. Old folder size is two periods as large as the Windows 7 drive free space, hinder system restore attribute and also disk cleanup to get some free space.
3. Put in your Windows 7 installation disc in the male and reboot your engine. Push any key when encouraged to do so.
4. Select language, moment, keyboard type and then hit the Nex to go on.
Open your Windows 7 drive (usually C drive) and make certain that you haven’t deleted the Windows. Old folder, which was created by Windows while installing Windows 7 on XP drive. Note that without the help of Windows. Old folder you won’t be able to downgrade from Windows 7.
Now check the size of Windows. Old folder by right-clicking and then selecting properties. Make sure that Windows. Old folder size is less than two times the amount of free space available on Windows 7 drives (C drive). If the Windows. Old folder size is two times as large as the Windows 7 drive free space, disable system restore feature and also disk cleanup to get some free space
3. Insert your Windows 7 installation disc in the drive and reboot your machine. Press any key when prompted to do so.
4. Select your language, time, keyboard type and then hit Next to continue.
To downgrade from windows 7 to windows XP, you need the Windows XP cd. Insert it to your drive and reboot youur system. Press boot from CD and follow the simple steps that you will be taken through while installing Windows XP. The process should take at least 10 minutes to finish. Once it is done, your phone willl restart and your Windows XP will be up and running.
If you don’t like what you see in Windows 7 and you don’t need the many features it offers, shifting to a much lower operating system like Windows XP is not a problem but the process is different because downgrading is not possible.
You can upgrade from a lower operating system to a higher one without formatting your drive and keeping all your applications but you can never downgrade like how upgrade works. If you want to replace your operating system, Windows 7, and shift to a much older one like Windows XP, you have to do a clean install.
A clean install means you have to format your system drive (C), where Microsoft Windows 7 is installed, and then install Microsoft Windows XP. And about your applications, you have to install them one after the other. To install the latest Service Pack for Microsoft Windows XP once you have installed it, download Windows XP Service Pack 3.
This is the latest and last Service Pack update for Microsoft Windows XP.
