How to download and install hp director?
I need your help because the last time that I did download some related program or software to this it crashed and the error always pop out on my screen, and that is very annoying.
Can you give me the best way or solution to fix this problem?
Thank you.
Best Answer by Julinee James
Answered By 10 points N/A #165086
To download and install HP director on your computer, follow the steps below:
1. Go to this site and download the setup file.
2. Check the compatibility of the software with your computer before you download it. Save the setup file on your desktop.
3. Run the setup file from desktop and follow the steps on the installer window.
4. Check the “add desktop icon” option at the end of installation.
Now, you can run HP director by using the icon on the desktop.
Answered By 0 points N/A #165087
Hi Marie,
  1. Please go HP site and press on “support & driver”.
  2. Check “download drivers and software” box and click next and enter your product number.
  3. Click on the correct link and choose your HP device.
  4. Choose your OS and click next.
  5. Now click “driver-product installation software” and click save file.
  6. Double click on the downloaded file to install.
To know more please follow the link.
