How to download and install norton desktop gadget for xp?
How to download and install norton desktop gadget in my windows xp operating system computer? I need a freeware version, but if there is no free download I will stick to shareware versions just to have a free access on the software. Thanks
Best Answer by Hood Winbush
Answered By 0 points N/A #129925
Norton desktop gadget is not available for Windows XP operating system. You may try changing your operating system to Windows 7 or later versions to be able to use it. For the meantime, stick to shareware versions. You may also try other free antivirus like AVG, Avira, or Kaspersky. They offer good service for free. Check the links below to download.
Free AVG Antivirus 2015
https://www.avira.com/en/free-antivirus-windows
https://usa.kaspersky.com/
Hope this helps. Good luck!
Answered By 0 points N/A #129926
There are a lot of antivirus software out there but the choice is up to the user and the specific needs and preferences. Most of them more or less do the same kind of protection with some slight differences. Most of the time it will all come down to things like ease of use, scanning speed, ease of update etc.
Techradar ranks the top three free antivirus programs as; Avast, Panda Cloud and Emsisoft Emergency Kit
