How to download and upload large files?
Hi All,
How can I download and upload files around 6GB through the internet?
I am surprisingly cannot get a good site and try upload.com which was too slow and can’t upload the 6GB files.
Cheers to all
Hi All,
Cheers to all
Hi user
Most fileservers wont allow you to upload a file sized 6 GB unless you have a premium account in the fileserver.
And your friend will have trouble downloading the file if he too doesn't have a premium account on that fileserver.
Your search would be in vain.
Another easier option is to burn the files into a DVD or get it into a flashdrive to transfer the files.
Hallo Steven,
Though I have got what you really need to be helped about your question but I am guessing it is something to do with the site you can use for downloading files, right?
Try using a download manager wherein you can schedule your downloading process with faster speed.
You can also set the filter to set the minimum and maximum size of the files that you want to download.
For uploading files, try the Uploading.com and get a monthly subscription to get a 50GB storage.
Regards
Mahesh Babu
Thank you for your solutions Mahesh Babu and Techyguys.
Looks like there is no way I can send the 6GB file online.
Maybe I’ll resort to burning the file or moving it to a flash drive and sending it to my friend.
Many thanks!
Thank you TechyV!
Notifications
