Hello guys,
How to download apache 64 for windows 2003? What website you can recommend to me that give the best, secure and proper way of downloading an application. Of course it should be compatible with my windows 2003 operating system. Thank you.
window 2003 has 32bit architecture so you need to download 32bit architecture. I am sharing website that contain 32bit apache server.
http://tomcat.apache.org/download-60.cgi
From above listed website you can have server of your need if this problem still there you must update or reinstall your operating system. All software updates come with new architecture of operating systems.
Hi Christina,
Apache 2.0.64 is the basic version .The new versions like apache 2.2.23 and 2.4.3 are available. You can download the apache server from the apache site itself. Here is the link http://httpd.apache.org/download.cgi
You can find separate downloading links for UNIX and Windows operating systems.
After installing apache you need to edit the configuration file. You need to set the path manually. Otherwise it may not work.
Thanks!
