How to download an Apple dvd creator for Windows?
I want to download apple DVD creator for windows and create DVD as the program attracted me. Unfortunately the current program I have not been supporting windows. Is there any apple DVD creator for window?
Please help me.
Best Answer by Miguel M Burch
Answered By 5 points N/A #157787
If you are looking for a DVD Creator that will run on your Windows PC, try the Xilisoft DVD Creator. This is easy to use and can convert file formats like AVI, MPEG, WMV, VOB, DiVX and more. It can run on Windows and Mac PC. Just click on the link below to purchase and download it:
http://www.xilisoft.com/dvd-creator.html
Answered By 50 points N/A #157788
Hello there Nick!
You could give DVDFab a try. It lets you create DVD disks from multiple video and audio formats.
You could create your own DVD Menu and also with a selection of templates you could use for the menu.
You may check out this link to know more about the features of this software that I have not specifically provided in my answer.
I hope this information helped you and I wish the good luck! You may also try other alternatives like Xilisoft DVD Creator which also creates DVD like DVDFab.
The choice is always up to the user. Cheers.
