How Download An Application That Can Convert WAV File To Text.
Asked By 35 points N/A Posted on -
Hi all, I am searching for a Tool that I can use to Convert WAV file to Text. I have heard about Audacity, but its interface was pretty difficult to use. So, someone, redirect me to a site that contains a tool that I can use.
Answered By 0 points N/A #200399
Hi, you can use Wave to Text Converter that you find on
www.digitalcoding.com.
Click on the hyperlink to open the website.
http://www.digitalcoding.com/free-software/scientific/Wave-to-Text-Converter.html.
You can convert WAV files to Text easily, using this tool. It is available for free.
Click on the File menu, and select the Import option.
Choose the WAV File that you want to convert.
You will automatically see the text when you import the WAV file.
