Hello experts,
How to download an application for marine map lumia? I got my Nokia lumia mobile phone and I was wondering if it has the ability or feature that can handle any map related such as marine map, GPS or other map tracking software? I hope you can share with me your best idea.
Thank you.
To download apps on your Nokia Lumia mobile, you have to go through to Marketplace using the button homescreen. You then can browse lots of apps through variety of categories including games, music and many more to download your suitable app. For better performance and satisfaction, you should have to go through recommended or most viewed apps so that you may able to download your favorite app.
Curtis Marry, In regards to that matter. All you have to do is go to http://store.ovi.com then set and update the device/phone model to see compatible applications. Download nokia Ovi store application then installs it.Â
When you have installed the nokia Ovi store application on your Lumia phone. Get register and enjoy downloading a lot of applications, videos, images. Personalization, games, utilities etc.
Regards!
