How to download avast Antivirus for my pc protection
Asked By 7060 points N/A Posted on -
Hi!
I am a new computer user and to properly defense my computer I need Avast Antivirus.
But I do not know how to download this Antivirus.
Now I require the downloading process of this Antivirus.
This is more essential for my computer's protection.
Best Answer by Yohan
Answered By 0 points N/A #79926
Hi Amatin263,
It is so easy to down load Avast. Just follow the steps carefully with little search in the internet then you can find it.
Open Google by clicking here.
Type Avast + Free Download > Open the second result > click download. After you finish downloading the title Run installation and Restart your computer. Buy the serial number from Avast official website Enter serial number > Restart computer for applying changes,
You can download
Avast directly from this link if you can't use Google research.
Note : The downloaded version is a version of trying you must register your product and buy the license key.
Answered By 0 points N/A #79927
Avast is a good Antivirus. This will help you to keep out of viruses. You can download the Avast Antivirus from different site. This is one of the download site of Avast. go to this site. There are three kind of Avast security you will see. First one is free Antivirus. There is a download (in blue box) option.
Click on the download, then box will appear where you will find two options. Yes, I want to upgrade and No thanks, I want free protection. Click on the No thanks, I want free protection.
Then another dialog box will appear having 2 options save file and cancel. Click on the save file option. Then your download will start automatically.
