How to download avg metropolitan Trojan? Well nowadays we all know that virus is fast attacking applications that will definitely harm the computer registry and system. I want to have a security antivirus that will detect and delete auto run viruses which is very dominant. Can you tell me on how to download avg metropolitan Trojan, for they say this is effective.
How to download avg metropolitan trojan?
AVG offer several security products, these include an Internet security suite,an antivirus and Premium security. AVG also offer a free antivirus for its users. All the above products are very efficient in combating malware and ransonware, that is if you frequently update the virus definitions.
Marry,
Most current antivirus software have runtime protection. You have scantime and runtime that the antivirus can pick up. Scantime means the virus scanner picks it up once the antivirus has scanned the file. Runtime is when the virus executes itself on the computer (which means now the virus is able to do what it was programmed for). You seem to be looking for an antivirus that can do both with ease. I would recommend two different applications for this. First and foremost the best application for preventing malware is Malwarebytes Anti-Malware located here:
https://www.malwarebytes.com/
The software is free but the runtime protection comes at a small cost to use. This means you can scan the files and catch them but if they attempt to execute themselves it will not catch the malware and rid it from your PC until you run a scan. I also strongly recommend Avast! antivirus for viruses and Trojans as it does not scan for malware. Avast! is one of the best antivirus on the market today. It can be found here:
https://www.avast.com/en-us/index
I highly recommend to run both of these applications together whenever the PC is in use for maximum protection from viruses, worms, Trojans and malware. Running both applications together is a great way to prevent any infections on a PC. Also remember to run scans with both scanners once a week if you can. This also ensures that no infections have the chance to spread or become more severe.
