How to download a bearshare messenger app?
While downloading some songs in bearshare It just came up to my mind that I need a bearshare messenger app so that I will be able to chat with my friends through bearshare while downloading songs chat with them. How to download a bearshare messenger app for free?
Answered By 0 points N/A #149738
Bearshare Messenger is usually available with the application.
To check if yours is equipped with a messenger, on the Toolbar, click "Help" then choose "About Bearshare". If the version number that you have is lower than “20957”, then you don't have a messenger.
The best solution is to download the latest version of the application. You can download it in https://www.pinnaclesys.com/en/free-trials/ for free.
If you are already using the latest version, you just have to look for the messenger in the application.
Hope this helps. Happy chatting!
