How to download the best enc php encoder?
Hello Experts,
How to download the best enc PHP encoder? I want it free from the internet if possible. I tried to research from the internet but some are not compatible with my windows 7 starter operating system. I hope you can share with me the one that is compatible with my present operating system, thank you.
Best Answer by Kathyn Roy
Answered By 0 points N/A #174468
Hi Melisa,
There are not much free software available free for use mean open source. I found some which can do the task required. Here is the download link of some if the software:
1. PHP encoder 5
This software will encrypt your source code using PHP cipher's online encode.
2. PHTML encoder 4
This software allows encoding of PHP scripts. This software works on all system which have PHP enabled.
Hope it helps.
Answered By 0 points N/A #174470
Hello Mellisa,
I will suggest you to use free PHP encoder.
You can also use Phrozen – PHP encoder, It’s also freeware encoded software.  Here is the download link
Illumination Tools
