How to download best quality Blu-ray movies?
I need to download some high definition Blu-ray movies. From where can I download them? How can I found the best quality movies? Someone please help me.
There is some very reliable site from where you can download high definition Blu-ray movies. Some of these sites are:
Etc. Etc.
For finding the best quality Blu-ray film you have to remember the following things:
1. Check the name of the encoder before download the movies. The best encoders I ever have seen are power, RKO, spider, McClassic. Power is my favorite.
2. Try to download 1080p rather than 720p. 1080p is the best for large screen LCD monitor. M1080p or m720p means they are encoded. Try to download those. Because there size is almost same, but quality is very much better. 4.37 GB Blu-ray movie is must be encoded. Because untouched Blu-ray movies are not less then 20 GB. Always download movies after checking screen shots.
3. https://tvmuse.cc is another great site to find all kind of movies’ & TV serials’ links.
Dear Devid finch,
Well the problem your facing is not a problem at all. It seems that you’re a movie freak and want to have all the movies in high quality for better experience. Well here I’m going to suggest you some of the possible way to download high quality movie.
1. Download High-Quality movies for free (Direct Link).
First of all I would like to suggest you those sites which are completely free to download movie and provides high quality blue-ray or your desired quality.
*** All these sites have blue-ray section. You can download from there***
2. Purchase High-Quality movies through net.
Sometimes it takes lots of time for a free site to upload a better quality movie after the release of the movie. So if there is no problem to you, you can buy the blue-ray movies. It may cost much. Some of the sites from where you can purchase the movie are –
Purchasing will include shipping charge. So choose the best way.
The most important thing to know about downloading blue-ray movie is that the blue-ray format of a movie takes a little bit time to be available in net. So you have to be patients to get the latest movie in blue-ray.
Now download your desired movie. Hope for the best.
Cheers.
