Hello Experts,
How to download the best software skinner tool? I need a skinner tool to personalize the background of some msn live messenger if possible and you can also choose on what category of background you want such as car, sports, food and many more. I wish you can give me an exact instruction to get this done properly.
Thank you.
Hello Deborah,
Good Day,
As for customizing MSN Live Messenger skin, there is a software called Messenger Skin Builder. It allows you to customize the log in background, text color, contact list, chat background, and many more.
For more information and for Messenger Skin Builder download, visit:
http://www.softpedia.com/get/Authoring-tools/Authoring-Related/SkinnerToo-SE.shtml
As for the software that lets you design skin for car, sports, and etc, check out this software call SkinBuilder.
http://download.cnet.com/SkinBuilder/3000-2212_4-75452341.html
Hope this helps you!
To get the best software skinner tool you can go to www.brothersoft.com site, then select software category and select your desired one and download as directed there. Your background should be natural color for the car and food, such as, sky-blue, white.
Thanks
