Recently I have been experiencing repeated crashes on my computer after I have encountered frequent error warnings. I am not sure if there is something wrong with my RAM. If I download boot memory tool, will it fix these errors and crashes?
Are USB memory stick boot utilities needed? Where can I download this software? I really don't really know how to do it because I have never done it before so please give me some step-by-step instruction on how to do it. Thanks.
How to download boot memory utilities to fix computer crash
Hello Devin,
Unfortunately, a bit more information is needed to make any kind of diagnosis.
You can always try troubleshooting your computer problems with some kind of a tool but if the problem is hardware it won't fix it – it will only give you the right directions what parts should be repaired, removed or exchanged.
I would suggest you to use the Hiren's BootCD. It is a completely free compilation of useful tools that will perform several tests on your computer to see what's wrong. The tools are pretty straightforward and once you choose the test or a tool you'd like to use it will do everything without you so there is no need for step-by-step instructions.
Hiren's BootCD can be also placed on the bootable USB drive.
I am suggesting you to follow the below steps;
Action 1
When a method fails, the very first thing to do should be to compute the equipment. When possible, start a delicate computer by means of simply clicking on the particular 'Start' press button, picking out the particular 'Turn off of Computer' option and also simply clicking on the particular 'Restart' press button. When this is simply not doable, start a challenging computer by means of depressing the particular reactivate press button or perhaps depressing and also positioning the electricity press button around the PERSONAL COMPUTER event.
Action 2
Should the method reboots good, search for your own methods before the collision. If you put in new software package, check out Step 7. Most of method fails are attributable to clashes and also problems in method registry.
Action 3
As the Windows Registry is usually a difficult data bank regarding layouts and also selections linked to many plans put in inside appliance such as the Main system, it's nearly complicated to spot possible problems physically. Open up the internet cell phone browser and also connect to the internet.
Action 4
Acquire and also install a registry better. The moment absolutely put in, start the particular registry better and also initiate a registry scan.
Action 5
The actual registry better will make an effort to deal with virtually any issues seen in the system registry recommendations and also might typically quick the consumer for the preferred actions the moment they came across miscalculation cannot be resolved. Permit the checking and also washing in order to complete and also computer the equipment.
Action 6
The system registry should currently possibly be clear. Being a preventive calculates, often scan and also clear the particular registry no less than every fourteen days.
Action 7
Should the collision was caused by freshly put in the plan, trunk in Safe and sound Manner by means of depressing the particular F8 crucial around the computer keyboard during the computer practice.
Action 8
Pick 'Safe Mode' from your Main system trunk option. This can be sure that simply the primary elements needed through the method will be rich.
Action 9
Click the 'Start' press button and choose the particular 'Control Panel' option. Inside Command Section window, pick the 'Add/Remove Programs' class.
Action 10
The following screen will present every one of the currently put in plans inside the appliance. Find the plan which induced the particular collision and also click on the 'Change or perhaps Remove' press button.
Action 11
Adhere to the particular quick to complete the particular uninstall practice. Reboot the equipment within Regular Manner.
Action 12
Do action 4 to be sure that the system registry is always nutritious and also totally free of orphaned registry recommendations.
I hope it helps you.
