How to download BPM 64 bit free for Mac
Hi
I am interested in downloading BPM 64 Bit free. I am using Mac OS X version 10.5. Please share the information if anyone has any idea about this.
Hi
Hi Alisa,
I’m afraid you cannot have BPM 64 Bit for your Mac OS since you have it at 10.5 versions.
I believe we have only 32 Bit for that as well as the 10.6 versions.
You can have either 32 or 64 Bit in versions 10.7 and 10.8.
Thank you for your time.
Hi Alisa,
Unfortunately, you cannot download and use BPM 64-bit if your Mac Operating System is lower than 10.6. In this case, as you stated above, you have Mac OS X version 10.5 which is not compatible with the system requirements on using BPM in a 64-bit platform.
Please click the link below to review the system requirements for 64-bit operation.
System Requirements for BPM 1.5 – This link will guide you through the system requirements for BPM version 1.5.1. Also, it includes the detailed description of 64-bit operation and hard disk format.
Ware
Notifications
