How to download bubble shooter offline game?
I use to play the bubble shooter online game in my laptop. But now that I have my android mobile phone with me I am thinking to download a bubble shooter offline for free. How to download and install it in my mobile phone with an operating system of android?
Best Answer by Andrew Shakava
Answered By 0 points N/A #130142
The easiest way to download Bubble Shooter so that you can play it offline is to download it in Google Play Store. Connect your Android phone to the internet or to a WiFi, then open Google Play Store–you can find it in your main menu. In Google Play Store, search for Bubble Shooter. When you find it, just select it. Press the download or install button to start downloading. Once the download is complete, it will automatically install. All you have to do is to wait for it and you are ready to play Bubble Shooter.
Answered By 0 points N/A #196825
As like the above answer best option to download the bubble shooter game is "Play Store".  Please follow the below steps to download the free bubble shooter game from "Play Store". You should have any Data connectivity available on your phone to download the application
  1. Open the "Play Store" from your Android phone
  2. Select the Games menu
  3. Select the "Top Free" menu
  4. Search for any bubble shooter game
  5. Select the application and select Install option
 I am recommending below bubble shooter game for you.
  • Shoot Bubble Deluxe
  • Bubble Shooter
  • Bubble Worlds
  • Bubble Poke
  • Bubble Break
Another alternate way is login to your google account from your PC and download it. Follow the below steps to perform this.
  1. Access Google Website
  2. Sign in to your Google account
  3. Select the Apps option from the upper side menu
  4. Select the "Play" option
  5. From the list select "Apps" option and select "Games" option
  6. Search for "bubble breaker"
  7. Select the game you wish to install
  8. Click on Install button
  9. Select the Device and click on the Install button
  10. After the above step game will be automatically installed on your device.
Andrew Shakava
