How download camtasia videos with IDM?
Is it possible to download camtasia videos using the internet download manager? I saw read some manual steps on how to download such videos but it involves programming which am not so familiar with.
I don't know if it's possible using internet download manager but there exist other ways to download camtasia videos without any programming.
You can use the Firefox add-on video downloadhelper , It's very easy to use.
Another possible way is to check the temp folder , the video you watched will probably be there , if you can't find the temp folder just go to Tools -> Internet option -> Files
If you can access the page source code you can look for the .swf/.flv file
If you want to download Camtasia videos with IDM or Internet Download Manager, it is possible but a bit tricky. The task involves viewing the source code of the page and searching the file manually. To try this, open the page that has the Camtasia video and press CTRL + U to view the page source on another tab.
On the source code tab, press CTRL + F and enter the search term without quotes “swf” then hit Enter. Normally, the page contains only one instance of the video often using the default name “flash_controller.swf.” If you located this term on the source code page, remove the part “_controller” from the file name and add the URL of the page.
Like if you are watching the video in “TechyV.com” then you will have something like “TechyV.com/flash.swf.” Now, to download this with Internet Download Manager, click “Add URL” then enter the URL and click “OK.” See if this works.
