How to download china mobile apps?
How to download china mobile apps? Like cool games and other important applications for china mobile phones for free. I am asking your suggestions and ideas.
Regards, Alex Baker.
Hello, you want to know how you will download china mobile application. At first you need to know which application work on you mobile. Normally a java / jar file works on your mobile. This you can find on your mobile manual which file work on it . If the java files work on it then you can download files from these sites- www.getjar.com or www.mobile9.com. The both site are known good for application,games,themes etc.
Thanks
Eaana Albert
If your phone supports java applications, Download in .jar format. (Example: www.mobile24.com) then copy .jar file from computer to your phone (Example: downloads folder). Use your File Manager on phone to find the folder where you copied the file. Click on the .jar file and click Install you should find it installed in your game folder or extras.
When downloading Android applications from the Google play store onto your China Smartphone, it doesn’t necessarily mean that the application was also developed by a Chinese game app developer. As long as your China Smartphone operates on Android mobile operating system and the application you are downloading supports or compatible with your Android version, you can install and use it.
I know before, China blocks the Google play store website from their country. But several years ago, they began to allow Chinese mobile users to access the website and that’s how some Chinese got interested in developing their own Android application. When downloading an Android app from Google play store, check the information below the page to verify if it is compatible with your phone.
Normally, the compatibility of most Android applications varies depending on the Android version on the Smartphone and the model of the device.
