How to download compact cursor mania software????
Please can someone help me download the compact cursor mania software.
I need it to get the freelance job ID IN ORDER TO GET AN ONLINE JOB and work with cinch.
Would appreciate help.
Thanks!
Thanks!
You are talking about the cursormania software required to get your freelancer id registered? Well, as far as my research tells me there is no such software as a cursor mania software.
Even if you search the most popular software download sites, the closest you come is the cursor mania utility that makes your mouse pointer as if it is drunk or something. If you want, here is the link for you. You can check it and other related software here.
http://www.download32.com/download-cursor-mania-software.html
Thanks a lot Richie for answering and yes that's exactly what I needed it for.
But sadly it doesn't exist. But Anyways thanks, will quit searching for it at least!
Notifications
