I just want to ask about how to download convert to stl? Applications or any software related to this. Any url links and websites that are giving the user an access to download a freeware version. I was unable to have a successful download before regarding this matter that is why I really need your suggestions.
Thank you.
How to download convert to stl?
Stl converters are very rarely available on the internet.
I found some but they are the paid software.
However I came across a website where you can download a stl converter for free.
Click on the below link to go to the website.
Scroll down to the last and enter your email address in order to download the software.
Thank you.
Hello Lindsay Wendy,
There are a few sites from where you can download STL converter software. You can download the software from http://www.solveering.com/instep.html. You can get a demo version from there.
You can also check on the site softpedia.com which is good as well. Otherwise there are few official websites but there you have to buy the software. Choose the site from you want to download. Hope this could be a help.
Thank you.
STL Converter is used to convert CAD file formats such as IGES, ACIS, STEP and more. For this, try the InStep Version 2.0. It can be able to convert different file formats. It can also import/export other file formats such as OBJ, DAE, VRML, X3D and more.
