How to download cool wallpaper gif? I prefer downloading wallpapers in gif form than jpeg for some compatibility reasons and purposes there are some application that doesn’t support a jpg file but supports gif. I need your help and suggestions.
Thank you.
Hi Ericson Eric,
As you know, from Google you can find a lot of forums but the chances of getting the right solution depends on where you post your problems. We have so many different forums to get download cool wallpaper in gif format.
So classifying and posting them on relevant forums is the best way to get download the wallpapers and you can also convert images in any other format to gif format.
I can suggest you some good forums, which are listed below:
Downloads wallpapers from: http://gallery.mobile9.com/
And convert your images to gif format from:
1. https://image.online-convert.com/convert-to-gif
2. https://www.sodapdf.com/jpg-to-pdf/
Hi Ericson Eric,
I read your question and try to find a solution. As i surf the internet, i found many solutions. I chose the easy way/step to answer that problem. I will link you the URL and then follow the instructions.
The most common website to find images are google and yahoo. You will just choose.
You will type "cool wallpaper" or type the wallpaper you want to see. Ex. Anime wallpaper
Save the wallpaper you chose in your PC or to make it easy CTRL+C the URL.
Click this link http://www.zamzar.com/
As you click the link it will guide you step by step to make your wallpaper in GIF. Format
I hope it can help.
Thank You.
