annie brown
20 points
Posted on - 09/10/2012
How to download cost accounting books in pdf file format? I need this books for a reference, and I just want to ask if a pdf file can be downloaded in a computer with an operating system of windows xp? Because sometimes compatibility error occurs.
How to download cost accounting books in PDF?
PDF files are downloadable in any operating systems including Windows XP.
The possible reason for compatibility error issues is because you don't have a PDF reader installed in your computer.
In order to open a PDF file, you should have a PDF reader. Adobe provides free software for reading PDFs. You can download it from this link https://get.adobe.com/reader/
Once you have installed the software, you will be able to open the PDF files that you have downloaded.
Hope this helps. Good luck!
