How to download creative wave studio mp3s?
I am a fan of listening to music and also fan of downloading mp3s from the internet.
I just want to know the correct procedure on how to download creative wave studio mp3s?
Tell me more about this.
Best Answer by Runyon Grace
Answered By 0 points N/A #128590
Creative Wave Studio is a sound editor that supports WMV (Windows Media Video) and WAV (Waveform Audio) file formats.
It does not support MP3 which is another file type.
To download audio files for Creative Wave Studio, you will files that are in .wav (for example the song Eternal Flame, EternalFlame.wav) format.
Hope this helps.
Good luck!
Answered By 5 points N/A #128591
Creative WaveStudio is not an MP3 Player. It supports only WMV and WAV formats. However if you want to listen MP3 on Creative then you need to purchase Creative Audio Pack which will give you the option to play MP3 files.
This software will cost you $9.99. You can purchase this version online.
link will guide you further:
Second option is to use Windows Media Player or VLC Player to listen MP3 files.
I hope this will solve your problem.
