How to download css form builder plug in?
I need to download the CSS Form Builder plug-in, but I couldn't find it. And also, I need to know how I can install it. What are the steps needed and how do I configure it on my system?
Hi Robert,
You did not mention what framework or software you are using. There could be multiple ways of doing it depending on the CMS framework you are using. I will be very specific, assuming that you are using WordPress. You can download Visual form Builder. Once you have downloaded it. You can follow these step below.
1. Go to Plugins; Add New
2. Click the Upload link.
3. Click browse and locate the visual-form builder file you have downloaded.
4. Click Install Now.
5. After WordPress installs, click on the Active Plugin link.
Hi RoberCBusch
Assuming that you are using Joomla CMS, there are several form builder plug-ins available for download. Some are free and others you will have to pay a subscription fee. You can download Joomla CMS plug-in for form builder from https://www.rsjoomla.com/joomla-extensions/rsform.html
For instructions on how to install and uninstall this plug-in follow this link https://www.rsjoomla.com/support/documentation/rsform-user-guide/installing-and-uninstalling.html
To Install a Joomla Plug-in follow below steps:
