How to download dbf class in basic php function?
Hi guys,
I need to download dbf class that will give the extract information from the database file. It will be migrated from dbf file to any other format. This class is able to process only for dbf format in PHP functions. For these special qualities, I am looking to download it. Please inform me the download process.
Answered By 0 points N/A #168634
Hello, John Abbot!
This is very easy to download dbf classes. You just need a data converter, which can extract the files to other formats. You can try with RTA-600 Converter. RTA-600 Converter can make the various file formats for the database and that can be extracted to another format.
Here is an image to show this data converter. You just connect to your device from which data will downloaded. RTA-600 makes the data format that you will choose. Hope this answers your question.
DBF Converter
Have a good day.
