How to download delphi and Chinese font? Last time that I did a download was a failure, the error says unable to download file or sometimes unsuccessful installation problem occurs and I don’t know what more I can do just to get a free download for this font. Can you give me some idea and solution for this problem, I am using Windows XP operating system. Thank you.
How to download delphi and chinese font?
You have download invalid font files or you have access a dead download link. You can download the fonts in http://www.fonts101.com. It got a tons of free fonts ready to be download. So if you want to try other fonts you can search on their website.
After you have downloaded your font you need to put it in the Fonts Folder located on the control panel. To access the font folder on the control panel, Click Start then control panel and select Fonts folder. Paste your downloaded font to the folder so you can use it in your computer.
